This will work as will Build Array as shown in the attached picture. Note that you cannot add just a single element in 1 column. For example, row 5, Column 0 cannot have an empty value when Row 5, Column 1 has something. That is simply an invalid array. When inserting a single numeric element into a row, the default value for the other columns will be 0.
