Hi Alan
You have to build an installer. In the Application Builder there's a tab "Installer Settings". Select "create installer" and click the "Advanced" button. A new window appears, where you can select things to include. Select "Datasocket Support".
If you then build the application, a installation routine (.msi) is create. This you can install on a target machine and the datasocket function should work.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
