03-19-2016 05:10 PM
I have acquired current and voltage values of which I'd like to plot XY graph.
Problem is these are 1D waveform.
1. Please tell me how can I accumulate these value to array so I can have my XY plot.
2. Is there any other way to plot real time XY graph of acquired values.
(I am using NI 9205 analog module. I can see real time waveforms i.e. current vs time and voltage vs time on my front panel.
I need current vs voltage of real time values.)
please help out.
thanks.
Solved! Go to Solution.
03-19-2016 06:22 PM - edited 03-19-2016 06:23 PM
First use Index Array to get the two waveforms out. Then use Get Waveform Components to get the Y components of each waveform. Then use Build Array and wire that to your XY graph.
03-20-2016 02:06 AM
Actually, I have acquired 3 phase voltage and currents. I have to plot 'average current vs average voltage'. I have attached a test VI. can you please modify that to show me how to accumulate those changing values in an array so I can plot XY graph.
thank you.
03-20-2016 04:35 AM - edited 03-20-2016 04:36 AM
Try something like this....
Notes:
03-20-2016 02:29 PM
Thank you for your suggestion. But I have to accumulate the acquired values in an array to plot the XY graph. Because I won't just plot current vs voltage. I am also planning to calculate torque, speed and power values from current and voltage data and will be plotting torque vs speed, torque vs power plots.
So, please suggest me an alternative way where I can,
1) Accumulate the acquired values (via cDAQ) in an array.
2) Plot real time XY graph.
3) flush that array whenever it seems overflow OR flush older values while recent values keep accumulating in the array.
My previous comment has an attached VI. please help me out.
Kunal C.
03-20-2016 03:51 PM
The complex array contains all the acquired data, so you can calculate any derived values from it.
05-02-2016 04:41 AM
Hello all,
I am using Labview 10. I need to plot a XY graph in the case both x and y values are changing. For example x=1, y= 2; x= 2, y=3; x=3, y=4;.......like that x and y values are changing continuosly. i tried to plot, but the XY graph screen shows the instantaneous values of x and y. But I need all the plot of all the x and y values.
For your referecne I attached my VI.
Kindly help me in this regard,
Thanks in advance.
09-21-2017 03:25 PM
Hi KUDOS!
Did you mange build that XY Graph to plot it in real time?
