Hello Alberto,
the problem is somewhat different:
You can jump with the TAB key from one control to the next. If the control is a single element (like all the
numbers, booleans or strings) you can immediately change their value. If the control is an array, you cannot change the value nor the index. You have to select one of them WITH the mouse, to select and change them. And that's the problem!
I can change all values on a front panel only using the keyboard, but when encountering an array I have to use the mouse...
No way out?
Gerd
