05-21-2016 03:35 AM
As the RIO device ca access remotly but how to access VST 5644R target across network?
05-21-2016 10:13 AM - edited 05-21-2016 10:14 AM
Hi mmdhadwe,
This kind of depends, is your VST inside a Realtime PXIe or a Window$ one? If it's an RT one you can access it quite easily through MAX and then adding it's IP address to project. If it's a Windows one I guess it depends what you're trying to do, but you could just remote desktop to the PXI?
Dan
05-24-2016 02:25 AM
Thank you DanHarryman for reply.
I am trying to generate pulse data using sample example in labview.
I am using VST 5644R in PXIe 1085 chassis with PXIe 8135 controller and I want to generate pulse data or any signal remotely in same network.
Thanks in advance
05-24-2016 02:56 AM
Hi mmdhadwe,
Are you using a Realtime operating system or a windows one?
Dan
05-24-2016 04:02 AM
I am working on windows OS.
05-24-2016 05:40 AM - edited 05-24-2016 05:41 AM
I guess it depends how deterministic you need the trigger to start the generation to be. I'd start by looking at network published shared variables to start the acquisition. They're not the fastest way to send data over the network but probably one of the easiest. The paper below states how to use them You can access the same variable from a number of different PCs on the same network so this should get you started.
http://www.ni.com/white-paper/4679/en/
Dan
