04-29-2017 07:03 AM
Hello All,
I'm pretty new to Labview and looking for your help.
I have a formula node that has 36 output values and I would like to store them in a 6x6 Matrix. How to do that?
Thanks in advance.
Solved! Go to Solution.
04-29-2017 08:33 AM
04-29-2017 09:02 AM
I have attached the VI.
I have 36 outputs that are calculated based on the formulas and given input values inside the formula node. I would like to use that 36 output values to make a single 6x6 matrix, each output value as an element of a matrix, j11 to j16 first row, j21 to j26 second row and so on...
J11,J12,J13,J14,J15,J16,
J21,J22,J23,J24,J25,J26
J61,J62,J63,J64,J65,J66
04-29-2017 09:51 AM
04-29-2017 09:58 AM
04-29-2017 10:19 AM - edited 04-29-2017 10:30 AM
I'm already pretty amazed by the help but I guess things work like this in here.
It's been a few days I've started using Labview, deeply sorry to hurt your eyes...
Here is my new beautiful VI. I would like to create a matrix with the calculated values. How to do that?
04-29-2017 10:25 AM - edited 04-29-2017 10:28 AM
I can't open or see your VI, but the image shown above is definitely not the right way to do it.
I always try to use the structure of the data to guide the structure of the program. If you want results in a 2-D array, it's good to use 2 nested loops. You want the results to be 6x6, so each loop should run six times.
After you've picked the structure, you should ask two questions: (1) What part of the calculation is the same for each element? (2) What part is different?
The part that is the same should be on the inside of the loop. The parts that change for each iteration should be on the outside. In this case, I didn't wire the "N" values for the loops. Instead, I use the array structure of the input constants to tell the loop how many times to run. Notice that the "a" constants index on the inner loop and the "b" constants index on the outer loops.
So the first row uses b[0] for all six values of a (a[0], a[1], etc.) The second row uses b[1] with all six values of a, and so on.
By using indexing outputs on two loops, it automatically creates a 2-D array of 6x6.
I hope this helps.
If you can save your original (or next iteration) for LV 2012, I could help you more.
04-29-2017 10:29 AM
Apologies for the earlier response.
I think that the summary would be something like this: If you want to write the code in LabVIEW, there are likely more direct methods than implementing the code in a box containing text-base code, then outputting an enormous number of wires.
For some of the calculations you're carrying out, there are simple(ish) mathematical representations that do the same thing - for example, it appears that the first block is a matrix rotation, which can be carried out by multiplication of two matrices. LabVIEW contains tools to manipulate matrices (under the array palette) and so doing the calculation in more native LabVIEW code might be easier, both to code and to read.
04-29-2017 10:43 AM - edited 04-29-2017 10:45 AM
I responded earlier, but it looks like my post was deleted. Not sure what happened.
Could you save your VI in an earlier version of LabVIEW so I can work with it?
In my earlier post, I suggested using the structure of the data to guide the structure of the program. If you want the output to be a 2D array of 6x6, it makes sense to use 2 nested loops that each run six iterations.
Below is a simple example: The "a" constants iterate on the inner loop and the "b" constants iterate on the outer loop. As a result, the formula node gets all possible combinations of "a" and "b' inputs. Indexing on both loop outputs creates a 2D array.
04-29-2017 10:44 AM
I have a lot of pages of Matlab Script code so trying to make them run in Labview as well. I know there would be plenty more sophisticated ways to do it but that's another thing I guess.
I just want to put that already calculated values in a matrix, is that possible?
