How to Convert decimal(12.51) to hex value??
Hi All,
I am using LabView 8.5.
I have to convert decimal to hex value to write the data into MCU.
But my value is decimal like 12.51.
How can I convert?
Cloud
Message 1 of 8
(2,546 Views)
Hi All,
In additional information to my question,
I need to convert the decimal value 12.51 to byte[] to able to write into MCU through RS232.
Jessie
Message 2 of 8
(2,539 Views)
How many bytes do you want to represent this value?  (4 bytes for single representation, 8 for double).?
Use the typecast function.
Message 3 of 8
(2,536 Views)
Hi Cloud5,
 Please see this http://digital.ni.com/public.nsf/allkb/DD5AFE8E829DC16D86256BDF005E1F95.
SrikrishnaNF
Srikrishna
Message 4 of 8
(2,509 Views)
Hi Cloud05,
On the indicator, right click> select representation> select I16 (Word)
This will allow you to select display format in the properties dialog box.
Now press right click> select properties>Click display format> select Hexadecimal in the Types menu.
You should see small 'x' on the left of indicator indicating the value in Hexadecimal
Please see attached image.
157+ CLDs & 9 CLA Trained
LabVIEW Training resources
Message 5 of 8
(2,492 Views)
How is the number supposed to be represented according to the manual? Some, e.g. the pump i'm working on right now, uses 1/100s as integer, i.e. 12.51 would be read/sent as 1251. Is the number supposed to be the hex representation or the text representing the hex? (Is it supposed to send 04E3 or the text '04E3')
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 8
(2,484 Views)
Please check attached VI.
One array shows 8 byte representation (When 12.51 is considered as double precision)
One array shows 4 byte representation (When 12.51 is considered as single precision)
This way u can convert it to array and then transfer to serial port.
If this is what u r looking for , pls dont forget to add Kudos.Smiley Wink
Miraz
With Regards
Miraz
Kudos is better option to thank somebody on this forum
Message 7 of 8
(2,437 Views)
Please check attached image
If this is what u r looking for , pls dont forget to add Kudos.:smileywink:
Miraz
With Regards
Miraz
Message 8 of 8
(2,431 Views)
