07-01-2005 02:58 PM
07-01-2005 03:30 PM
07-01-2005 04:50 PM - edited 07-01-2005 04:50 PM
A boolean is really only good for two states (true/False). If you need more states, I would use a colorbox instead. It can easily be made to look like a boolean (see my old example here). Now you would simply pick from a set of colorbox diagram constants, depending on the desired color. This is much more elegant than having to mess with property nodes.
The attached example (LabVIEW 7.0) shows a simple demo. 🙂
(To make the LED color box indicator, I customized a plain color box and simply imported the graphic elements from the regular LED indicator.)
Message Edited by altenbach on 07-01-2005 02:51 PM
07-01-2005 05:26 PM
Hi Randall, Thank you for your reply. Could you make it in Labview 7.0.
David
07-01-2005 05:34 PM
07-01-2005 06:32 PM
07-01-2005 06:46 PM
07-01-2005 07:07 PM
07-01-2005 07:30 PM
07-01-2005 07:34 PM
