How to Connect the Kinect to Labview
hi, have you found any example? could anybody tell me where should i start???
Message 11 of 20
(3,575 Views)
And what is the problem that you have ?? Are you using the new SDK driver ?
Message 12 of 20
(3,565 Views)
 i was try ti install sdk 64 from nicrosoft page, but it ask for OPEN NI, then i download OPEN NI, but there are many files, how install OPEN NI in my PC????
Message 13 of 20
(3,557 Views)
Follow instructions under link below,
http://ryangordon.net/2010/12/26/kinect-for-labvie​w-part-1/
SDK drivers are easier to install, but some of the older sample VI provided are using the OPENNI driver.
You can alway try and modify them to use SDK driver dlls
Message 14 of 20
(3,548 Views)
Guys, they are several links that you can use.
First of all, I have the drivers that I did, they work well, but we need to do a main program. They are not ready yet, if someone is interesed, let me know.
https://decibel.ni.com/content/docs/DOC-15655
Second, we have Ryan's Drivers, with those drivers I did my program, go and check it out, it's quite interesting.
https://decibel.ni.com/content/docs/DOC-17771
And the last but not the less important, the SDK drivers, I did a benchmark, and I modified a little bit the program. I still prefer Ryan's, compare yourself and use which best fit for your porpuse.
https://decibel.ni.com/content/docs/DOC-17265
"Everything that has a beginning has an end"
Message 15 of 20
(3,543 Views)
a first approximation to use the Kinect sensor is Kinesthesia Toolkit for Microsoft Kinect - the University of Leeds, Initially developed for medical rehabilitation and surgical tools at the University of Leeds, the Kinesthesia Toolkit for Microsoft Kinect helps experienced and new NI LabVIEW programmers quickly access the popular functions of the Microsoft Kinect camera such as RGB video, depth camera, and skeletal tracking.can be downloaded from the following link
http://sine.ni.com/nips/cds/view/p/lang/en/nid/210938
Message 16 of 20
(2,681 Views)
here have a developed based on the OpenNI Interface example, you can compare it with the previous example developed for microsoft SDK
https://decibel.ni.com/content/docs/DOC-16978
Message 17 of 20
(2,666 Views)
LabVIEW Kinect Interface from Labview Hacker is recommand:
https://www.labviewhacker.com/doku.php?id=projects:lv_kinect_interface:lv_kinect_interface
It works at Windows 8.1 enviroment.
The Labview loads data directly from MS Kinect driver and then displays image
LabVIEW Kinect Interface needs NI vision, it could be a limited.
Message 18 of 20
(2,558 Views)
i want to connect kinect to labview , i downloaded sdk driver 1.8 and developer toolkit , and http://www.ni.com/download/ni-vision-acquisition-software-september-2013/4409/en/ , but labview cant detect kinect , what should i do ?! can u show me the steps
Message 19 of 20
(2,417 Views)
You might want to also try posting this to the LabVIEW MakerHub forums, https://www.labviewmakerhub.com/forums/
Message 20 of 20
(2,398 Views)
