03-02-2017 07:26 PM
Hi, I am using LabView to control a Electron Beam furnace to melt metals. The current EB scanning pattern controlled by LabView is a circle as shown in the following figures.
I would like to change the current EB pattern to a circle with a gap. Electron beam needs to change direction continuously and move clockwise-anticlockwise-clockwise-anticlockwise-... I also would like to control the angle for the gap and its position. Does anyone know how to do this by LabView? I have been struggling with this problem for a while.I appreciate your time very much if you can help me in any way.
03-03-2017 01:54 AM - edited 03-03-2017 02:11 AM
Hi Jason,
So all you need to do is to provide the corresponding XY cooridinates!
Well, yes: you need to calculate the needed XY coordinates!
For circle segments this is quite basic math involving some sin/cos calculations…
(As Christian probably would suggest too: using complex numbers may simplify your calculations also. :D)
