09-03-2012 01:08 AM
Hello and Good Morning to all,
I have a text file with my data and i read them by using the Read From Spreadsheet File VI,i enter the path where my file is saved,read all rows delete the first row because i don't need it and my problem is that in the text folder i have specified date and time which i want to be my X axis in my Graph and Y axis to be the Vout that means i have to use a XY Graph ,below you can see my data:
Date time Vout
3-9-2012 7:45:37 2,35
3-9-2012 7:45:39 2,75
3-9-2012 7:45:41 3,15
3-9-2012 7:45:43 3,50
1) Is the text file format compatible with the input of the graph command?
I do not find a LabVIEW function which convert the “date” from the text file (example:3/09/2012 07:45:37) into a compatible format for X axis for the graph.
(Conversion from string format => into a “date and time” format)
Can someone please provide a code solution for this problem?
09-03-2012 01:21 AM
Hi gstathatos,
See all the threads given below:-
http://forums.ni.com/t5/LabVIEW/Add-points-on-XY-graph-with-time-step-not-constant/td-p/1507066
09-03-2012 01:54 AM
Hi Danil 33,
I saw the link you send me and unfortunately the information from the second and the third link is not working as it should.From the first link i try to understand if i can use it.
Any other code suggestions?
09-03-2012 02:28 AM
09-03-2012 02:53 AM
Hi GerdW, my data is being read from a text file so i use your vi along with reading the data from my text file but unfortunately is not working.In my graph on x-axis i don't see the time i have in my text file.I am sending you my vi maybe i am doing something wrong and you can fix it.
09-03-2012 03:00 AM - edited 09-03-2012 03:00 AM
09-03-2012 03:19 AM
Ok correct those two mistakes you told me but my problem remains in the x axis i can't see my time i have in my text file
09-03-2012 03:22 AM
09-03-2012 03:33 AM
In my XY Graph the X axis is as shown in the picture.I expect to see in my X axis the time i am reading from my text file.
09-03-2012 03:36 AM
Hi gstathatos,
you know you can change the formatting of the x axis to show also seconds and year?
You know you can check your data by using probes or indicators?
Are the timestamps read correctly from your text file? Did you check that?
You know debugging isn't easy when I'm not sitting in front of your computer!
