How to Access Item Names Property of ListBox inside of Cluster?
In LabVIEW 2010 I have a Cluster of Controls on the Front Panel. In that Cluster I have a ListBox. How do I access the Item Names Property of the ListBox in my Block Diagram.
From the Cluster, I can get the ListBox, but that returns an I32 value, probably the index of the selected Item.
In the Block Diagram, how can I get the Item Name Property of the ListBox from a Reference to the Cluster?
THANKS.
(4,010 Views)
Accepted by topic author dbaechtel
by using the "controls" array of your cluster, you can access the individual elements. You have then to convert the reference to a "more specific class" using a reference to an arbitrary listbox (or a constant reference of the required type), then you can access all properties of your listbox.
23532i1DB5485E431B7492
THINK G!! 😉
Using LabView 2010 and 2011 on Mac and Win
Programming in Microsoft Visual C++ (Win), XCode (Mac)
(4,003 Views)
From the original question, I gather that the OP does not know the label name of the listbox item.  The following code will get the labels of all items inside the cluster.
23536i0DE77F409A3C80EF
- tbob
Inventor of the WORM Global
(3,996 Views)
