Try to pass the reference of the FIFO to the "Target scoped 2", in this way you should avoid the flat sequence.
Do something like that:
1) In "Target scoped1" make a flat sequence in which you first fill the FIFO and in the second sequence call the "Target scoped 2" passing the FIFO reference;
2) In "Target scoped 2" you just copy the for loop you already implemented.
