Brinda,
When you acquire data with the Daq Assistant, the data is in the waveform data type. A waveform has 3 components: a time stamp, a delta T (change in time), and an array of Y values. So, regardless of what signal manipulation you do to that waveform, it will still contain the timestamp it was given when the acquisition was performed. The time that prints in the file will be the time that it was acquired, not the time it was written to the file. Note: this time stamp is taken from the computer's system time. Therefore, the accuracy of the timestamp will be dependent on the operating system (i.e. when the OS tells the LV thread to run, what other processes are running concurrently, etc). I hope this helps!
