How does the 3D Graph Object put an Indicator on the front panel?
When using the a 3D graph the output object is also the graph indicator in the front panel. How does this work? I would like to implements similar functionality with custom picture controls used to "Graph" data in much the same way.
(2,604 Views)
You can create an XControl with your custom graph.
Norbert
Norbert
Expert: Geometry
(2,518 Views)
