09-29-2014 02:40 PM
I created a channel using 2 separate voltage sources. However, both of these voltage sources are differentials across other channels on the DAQ board. Is there a way to set my physical channels as something like "differential w/ channel xxx"?
Solved! Go to Solution.
09-29-2014 02:48 PM
No, the differential pairs on DAQ boards are hardwired. Generally 0-8, 1-9, etc. but that depends on the card. Read the manual for your specific device.
09-29-2014 02:53 PM
Ok, so as long as I choose Differential for the "Input terminal configuration" on the "creat channel vi", I should be fine?
I am wired into the DAq board's standard differential inputs.
09-30-2014 09:56 AM
Yes, you should be all set. Here's a good read on wiring considerations: http://www.ni.com/white-paper/3344/en/
