How do you take into account a differential signal using daqmx?
I created a channel using 2 separate voltage sources. However, both of these voltage sources are differentials across other channels on the DAQ board. Is there a way to set my physical channels as something like "differential w/ channel xxx"?
(2,705 Views)
Accepted by topic author BennyDe
No, the differential pairs on DAQ boards are hardwired.  Generally 0-8, 1-9, etc. but that depends on the card.  Read the manual for your specific device.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019 - Unfortunately now moving back to C#, .NET, Python due to forced change to subscription model by NI. 8^{
(2,694 Views)
Ok, so as long as I choose Differential for the "Input terminal configuration" on the "creat channel vi", I should be fine?
I am wired into the DAq board's standard differential inputs.
(2,690 Views)
Yes, you should be all set.  Here's a good read on wiring considerations:  http://www.ni.com/white-paper/3344/en/
(2,641 Views)
