04-07-2014 12:04 PM
Hi LabVIEW Community,
I am new to LabVIEW and Im working on my first application. One of my challenges that I am having problems solving is how to subtract specific values from specific elements in an array.
My aplication is to measure the distance between a sensor and a magnet, however the initial distance for each sensor to magnet is different. I have converted the voltage to a distance using the Math Node for each element and now need to correct these values by subtracting their individual initial value.
The source is a 1D array of DBL64 consisting of 32 elements and each of these values needs to have a different value subtracted.
eg:
Element 1 - 5.557
element 2 - 2,34
element 3 - 7,654 and so on
I have tried to seperate (index the array) and subtract the values from each element and then combine them again. This has not been effetive. I need to write these values to an .txt file and also use them in another calculation.
I have attached my attemted sub VI.
Any advise would be really apprecieated.
Solved! Go to Solution.
04-07-2014 12:12 PM
Could you please upload your VI again for LV12?
thanks.
04-07-2014 12:15 PM - edited 04-07-2014 12:17 PM
Hello ectoxmussel,
The numeric operator primitives are polymorphic and can operate on your arrays element-by-element if you provide two arrays containing the operands.
It's simple once you know that it works, but if you don't read the help for the primitives it can be overlooked pretty easily - I've definitely been surprised in the past by things like this that "just work"!
Hope that helps!
04-07-2014 12:33 PM
Thanks for the quick reply,
Here is the Sub VI in LV12
04-07-2014 01:18 PM
You don't need to overthink it. There's a really simple method. Generate an array that contains all your offsets you want. Then subtract it off.
It's the same VI with this change:
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
04-07-2014 02:40 PM
Hi Tom L.
Thanks for your quick reply. I will have to look at it again when I go back to uni tomorrow.
Cheers,
04-07-2014 02:44 PM
Hi bsvare
Thank you for your help and advise. As an ecology student there seems to be no simple methods:).
I will run the modified VI tomorrow when I return to uni.
04-08-2014 05:22 AM
Thank you for your help. My program is now running and I am collecting data. It was an easy solution but it just never came to mind.
Cheers once again for your time bsvare!
