12-11-2012 01:22 PM
How do you convert analog data read from an external device at regular intervals to the Waveform Data Type? That is how do you add delta t information to analog data that is sampled at regular intervals.
Howard
Solved! Go to Solution.
12-11-2012 01:23 PM
Build Waveform in the waveform palette.
But if you are using NI devices, the DAQmx driver can be set to output the Waveform datatype.
12-11-2012 05:27 PM
Thank you for your reply. I noticed a couple of subtle things I initially missed. Like having to add an element and right clicking on attributes to get at delta t.
Howard
