09-21-2014 11:47 PM - edited 09-21-2014 11:48 PM
I tried using the the index array feature, and cant figure out where to connect the output.
I am trying to read the data into multiplt columns using the "array to spreadsheet" vi, but I don't know the proper sequences of Vi's between the Daqmx read (Analog 1D Wfm Nsamp) and the "array to spreadsheet" vi.
I attached my VI, but it is version 8.2 so it may be completely different
09-22-2014 12:11 AM
09-22-2014 12:14 AM
Here you go!
09-22-2014 12:24 AM
09-22-2014 12:36 AM
I'm sorry, I think I was misunderstood. The data doesn't necessarily have to be written to a spreadsheet. A .txt file is 100% fine, I just need it to write in columns of data for each voltage input. Does this alter your latest advice?
09-22-2014 12:42 AM
09-22-2014 12:44 AM
By "sampling information", are you referring to the sampling rate?
09-22-2014 12:47 AM
09-22-2014 12:52 AM
Shoot. The sampling rate is very important in this VI. I think I am having the most difficulty understanding exactly what is being output from the Daqmx Read Vi. Are 2 sets of data being output? If so, I just need to be able to somehow put those two datasets into columns in a .txt file.
Right now I use this sequence (it is not working): Daqmx read>>>build array>>> array to spreadsheet String>>> write to text file
When I tried including the "get waveform components", the output from Daqmx Read wasnt compatible with the "get waveform components" input
09-22-2014 12:57 AM
