Hi!
I´m a student, who´s trynig to control a gasturbine process for my diploma thesis. The control program should be written in LabView 8. I need to control 6 25 Hz PWM signals for the gasvalves. The needed accuracy of the duty cycle has to be about 0.1 %.
A tech. engeneer from NI told us , that we can do this by using one single digital output for each PWM.
Now, after a while, i need to implement it into my program. But there are troubles:
My NI-PCI-6221 standard card only has 2 couteroutputs and only the first of the 3 ports seems to be buffered (Error Nr. 201062)...
I tried to do the programming, by manipulating the "DIO_PWM_50Hz.vi" I found in google.
Does anyone of you have any information or helpful examples how i can create these PWM with my card, or did I get a wrong Information by the salesagent (...not the first time....)?
Thanks for your help
Tobi
