How do I unit test VIs with classes?
I have my first VI using an Object Oriented approach that I want to Unit Test. How in the world do I configure the Unit Test Framework to accept a specific class? See the attached snippet.
(2,968 Views)
Accepted by topic author elrathia
Hi elrathia,
Here is a link that should help you out:
http://zone.ni.com/reference/en-XX/help/372584D-01/lvutfconcepts/utfc_tests_cases/
At the bottom, you can see a location to an example:
labview\examples\Unit Test Framework\LabVIEW Class\LV Class.lvproj
(Note this is for 2012)
DylanC
(2,946 Views)
Ah. That will do quite nicely. Thank you.
(2,925 Views)
