04-18-2013 08:00 PM
Hello.
The hardware is as follows:
Labview 2009
PCI-MIO-16E-1
SCB-68 shielded I/O connector block
My job is to create a program that can work as a base from which we can create more complicated programs. I am new to Labview. I have watched some youtube tutorial videos and have a basic understanding of the program operation. I built a program that reads voltage values as you rotate a potentiometer, very complex I know, as a training exercise. From that, I see how to acquire data from an input. The next step is to write a program that turns on and turns off a solenoid via a button. Once I have that down, I can figure out more complex methods of turning it on and off using timing, pressure, etc.
I tried looking at some of the code from other projects, but it isn't clear what is going on. I keep searching for an example online, but I the examples are all beyond my level of understanding. Any help would be appreciated. Even if you just point me to a site that has step by step examples.
Thanks.
04-18-2013 11:47 PM
04-21-2013 01:36 PM
Thanks. I will commence the search immediately.
04-21-2013 03:56 PM
GerdW,
I think the main problem is I don't know exactly what to search for. Nothing came up when I searched "solenoid." I think I'm being too specific.
Is the act of turning on/off the solenoid called a trigger, or is a trigger an event that, when it occurs, triggers something else...like the trigger in an oscilliscope? I know, or rather I think I know, that DAQmx is what I need to do this. I also know I can use the DAQ assist or I can program it myself. I believe the former is currently above my skill level and the latter is even worse. 😉 Does the DAQ need to read in a value from the solenoid before it can tell it what to do? Should I just read the entire help topic on DAQ? I'm sure that wouldn't hurt.
I appreciate your help on this.
Darren
04-21-2013 04:34 PM - edited 04-21-2013 04:41 PM
goto Help>>Find Examples...>>Hardware Input and Output>>Daqmx>>Digital Output>>Digital-SW-Timed Output.vi
there you will find an array of buttons that output a digital TTL signal to port0, lines0-7 of your Daq
next question: does your solenoid take a TTL signal as an input? If not, you will need a driver like a ULN2003
you can use your AI to measure your pressure then use LV to algorithmically manipulate your DO's
04-21-2013 06:05 PM
Thanks for the response.
There is no Digital Output in Daqmx. The sub folders are: Alog Gen, Alog Meas., Control, Counter Meas., Dig Generation, Dig Handshaking, Digital Meas., Events, Generating Dig Pulses. I assume we're talking Digital Generation. In that folder there are two that look like they might work: Write_Dig_Chan.vi and Write_Dig_Port.vi. They are write digital output to channel and port, respectively.
I should mention I have a VI that works and turns on the valve, but I don't know what it is doing. I think I have a lot of reading ahead of me. There is a lot of vocabulary that I'm unfamiliar with, despite my larger than average vernacular.
I'm going to start reading and come back here once I have a good foundation of what everything does.
Thanks again for your help.
04-21-2013 06:56 PM
yes, that was for LV ver 2012, but you are on the right track...do come back with your questions
05-20-2013 04:54 PM
Thanks everyone for your help. The solenoids are actually controlled via a relay and that's controlled with a simple one line digital out. Thanks again!
