05-17-2006 01:00 PM
05-17-2006 01:43 PM
05-17-2006 02:54 PM
05-17-2006 03:59 PM - edited 05-17-2006 03:59 PM
Message Edited by BrianPack on 05-17-2006 04:00 PM
Message Edited by BrianPack on 05-17-2006 04:01 PM
05-18-2006 08:55 AM
05-18-2006 03:27 PM
This is fairly straight forword. You just need to OR the output of of your code to write every 60 loops with the output of the code that sets daq 3 to 0. The using the boolean output of the OR gate to decide wether you write the file or not.
So you want the vi to stop running once the threshold is passed and after daq 3 is set to 0?
This code should do what you want but with out the setup to really test it I make no guaruntees. It should write to a file every 60 loops (1minute) or if the 85c is passed. Also the vi will stop once 85c is passed (but after the file is written) or if STOP is pressed.
Brian
