I have a vi that I want to run in an FP2010 that contains 2 while loops, one must be Time Critical priority and the other Normal or lower priority. I will be using RT FIFO to transfer data between the two loops. The Normal loop will be used for communication with a Host PC.
How can I set the priorities of these 2 loops?
Can I run 2 separate vi's in the FP with each set to a different priority And transfer data between the two with RT FIFO? How?
I am using V6.1 and the customer does not want to spend on upgrading.
Chris
