How do I make the needle in the meter to move?
My indicator is moving but my needle is in the meter is not moving... how do I make it move? I have checked setting but nothing work...
(2,561 Views)
Can you post the VI?
Thanks as kudos only:)
(2,553 Views)
Hi Joel,
your indicator is moving, but it's needle stays still? Yu should explain that or even provide an example!
To set the needle of a gauge indicator: just wire a value to the terminal of that gauge...
(2,552 Views)
Share the code or else use gauge control.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(2,551 Views)
As Gonzo the Great would say: What a FANTASTIC idea!!
(2,521 Views)
Maybe it's just a BIT stuck.  Have you tried tapping it with your finger?  Smiley Tongue
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019 - Unfortunately now moving back to C#, .NET, Python due to forced change to subscription model by NI. 8^{
(2,508 Views)
