09-29-2008 08:26 PM
I downloaded a third party Labview driver for a temperature chamber (Watlow) and unzipped it to find it had an LLB library. I can access all the VIs through the LLB manager, but how can I take those VIs and import them into Labview so that I can then find them in my I/O instrument control Palette? Since these VIs are in an LLB, I don't know how to take them out of there and put them into labview 8.6. Any suggestions will be very much appreciated.
Thanks and regards,
Rick
09-30-2008 02:30 AM
09-30-2008 11:44 AM
Thanks for the response, I had already seen this article and it does not answer the question of how you actually extract the files from an LLB. I tried several different ways and none worked. This article referes to having an executable file with the drivers that installs them for you. My situation is that I don't have an executable that installs the files in the wrong directory, I simply don't have an executable and just have an LLB. Any other suggestions you can think of?
Best regards
Rick
09-30-2008 11:48 AM - edited 09-30-2008 11:49 AM
When I read this KB it exactly tells me in which directories I need to copy the llb file manually, so that I have the contained VIs in my Functions Palette in LabVIEW.......
09-30-2008 11:55 AM
OK, I understand, I just dumped the entire LLB into the directory and it worked! I thought you somehow had to extract the files out of the LLB somehow and then place them in the directory. Thanks for your time in helping out!
Locktofer
04-20-2015 08:21 PM
Hi, lockofer
Do you mean you just copy the original llb file to the right directory without extraction? I did that but it didn’t work. I have labview 8.2 and the operation system is windows XP.
Many Thanks
XJTUer
04-20-2015 10:22 PM
05-21-2015 03:23 AM
I have the LLB under the .instr folder as the link says , and cand see the drivers under the Function Palette. But I am not able to connect with the instrument and when I go to Tools -->Instrumentation ---> Find Instrument drivers my instrument driver is not under the Installed Instrument Drivers and my device is not under Connnected instruments. Running Scan for Instruments has no effect.
Tried to run an Example VI provided by the instrument manufacturer (a simple ADC example). The VI runs in continuous mode , but no error or warning reported, the ADC reading is always 0 (default value) no matter what voltage or channel I select in the ADC.
Any hint to resolve this? I understand that if the driver is installed I should see it in the Tools --> Instrumentation tab....
05-21-2015 05:44 AM
05-21-2015 06:31 AM
I am trying to use a Diolan DL2-N USB to I2C/SPI/GPIO adapter (https://diolan.com/dln2). This manufacrures provides Labview drivers for the board as well as example VIs. I just want to use them to access to all interfaces via Labview. After that I will design a test setup for our last product line using this adapter board.
What i did:
1) Fresh install of Labview 2014 (evaluaton version). System: DELL Precision M6800 (i7) , Windows 7 Professional SP1.
2) Install NI VISA drivers and NI-488.2 drivers (14.0).
3) Install manufacturer drivers as explained in the link given in this thread.
4) Run Labview. As said, I can see instrument driver VIs under the Function Palette and run example VIs.
5) Run NI MAX. No USB ports listed. Only COM1 and LPT1 (printer port).
6) I ran some windows test apps provided by the manufacturer to access to all the interfaces of the NXP microcontroller in the DLN2. Everything works. I can read analog/digital inputs, force digital out values and use the SPI and I2C (I see the SPI/I2C frame sin a scope).
I have spent one day seeing different links in NI website (have seen almost every demo video on the site) and still are not able to guess why Labview can't see my USB device.
Any hint?
Jose
