I coudn't fully see your vi because their where a few missing vi's but i think this will solve your problem.
Instead of initialising a cluster array, i think its easy'r to create a shift register and create a constant at the input.
Further more i deleted your sequence structure and replaced the 'replace array subset' into 'insert into array'.
Also i replaced the local variable 'ResultsArray_Output' which you where using with index array, by a constant array cluster
Message Edited by Tristan on 04-26-2005 12:41 PM
