trosier,
You have built the LabVIEW EXE and now have a Data directory and your build, which you would like to place in different directories using the Installer correct? If so, you can try to explicitly place the support files in the project and add those in the Destination View in the Installer Build Specification. This will probably include the Data directory as well since you need to include the entire Application Build Specification to the destination of the installer, but you can delete this either manually or with another EXE. If you are just trying to change where the support files are placed when building an EXE, on the Destination page you can change which folder on disk you want the support files placed.
Hope this helps!
Andy F.
