How do I implement a polynomial function to receive a desired output?
I am acquiring data from a NI USB-6002 DAQ.
I want to convert a voltage value to a displacement value.
In Microsoft Excel I made a table. I recorded voltage values and the corresponding displacement values.
I plotted the data and the best fitting line was a fourth order polynomial function which looked like this;                         Y = A + BX + CX^2 + DX^3 + EX^4
*A,B,C,D, and E are all constants which I have values for
*Y is the displacement value which I would like to ultimately receive
*X is the voltage value coming from the DAQ.
I am having trouble creating the block diagram for the polynomial function I would like to implement. I tried using the math functions but I'm not sure how to add a power to the data coming from the DAQ.
Any feedback would be highly appreciated.
Thank you.
(3,344 Views)
Accepted by topic author belae1ka
You could use the "Polynomial Evaluation" function to apply your polynomial coefficients on your X data…
(Otherwise use those simple numeric functions like Add and Multiply!)
(3,334 Views)
