Can I see the time on a 'time stamp indicator' outside the while loop?
Ik can't see the time when I connect a 'time stamp indicator' on the
little brown triangle of the while loop.
It's called a shift register and no you can't just do that. A basic premise of LabVIEW is dataflow. Data is not available from the while loop unitl it finishes. You can put an indicator inside. Is there a specific reason you need it outside?
