Reply
How do I generate a random integer from 1-5?
 If I use random how do I convert it to an integer?
Message 1 of 20
(32,166 Views)
Re: How do I generate a random integer from 1-5?
check out the conversion palette under "Numeric->conversion"
Regards
Guru (CLA)
Message 2 of 20
(32,155 Views)
For a Random Interger from 1 to 5 you do something like this:
Edit: I just realised, that the chances for every Number are not the same, so my version is kind of unusable for statistically correct purposes.
Its too early in the morning Smiley Wink
Edit2: Also I realise further, that my version won't output 1-5 but 0-5 so it is not even what you wanted. D**n what did I do Smiley Very Happy
Cheers
Message Edited by Pattos on 01-20-2010 01:17 AM
Message Edited by Pattos on 01-20-2010 01:21 AM
Pattos
LabVIEW Gretchin
Message 3 of 20
(32,154 Views)
Could you just use a +1 increment after the multiplication? What does the I32 do exactly?
Message 4 of 20
(32,146 Views)
Accepted by topic author Laudie3a
08-27-2015 04:09 PM
"To I32" converts your floating point number to an integer, as you specified in your first post as requirement. Smiley Wink
Here' a version that gives all 5 numbers with equal probability. Instead of explicitely converting to I32, I use the output configuration of the +1. Same difference. Smiley Wink
Message Edited by altenbach on 01-19-2010 11:39 PM
Message 5 of 20
(32,136 Views)
dear altenbach,
just some "additional" inputs to make it configurable... please kindly comment and advise. Thanks!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010
依恩与LabVIEW
LVVILIB.blogspot.com
Message 6 of 20
(32,120 Views)
A similar one here
Ian F
依恩与LabVIEW
Message 7 of 20
(32,092 Views)
Wouldn't you have to multiply times 4 vs 5. If the random number give you a one then you would get 5 and add 1 to it giving you 6.
Tim
Yanfeng, Global Automotive Interiors
Holland Michigan
Message 8 of 20
(32,063 Views)
Tim
Holland Michigan
Message 9 of 20
(32,061 Views)
No aestet, Altenbachs solution is perfectly fine.
The dice generate a Number between 0 and 1 (Not including 1!!) Multiplied by 5 that is a Number between 0 and 4.999999.
The next triangle always rounds the Number down, so that you can only get 0,1,2,3 and 4 everything with equal propablity.
Plus one you get 1,2,3,4 and 5.
Pattos
LabVIEW Gretchin
Message 10 of 20
(32,055 Views)
