08-31-2007 07:06 AM
08-31-2007 07:26 AM
Create your own save to Excel function. Use tab-delimited format. Time<TAB>Volume<CR>, etc.
@SRBB wrote:How would I be able to create an excel file from this information?
I would like the excel file to have the time in one column and the volume at that time in the next column.
I though that I had wired it correctly, however I feel that the time seems to be a little off and very exact.
If anyone has ideas about how to do any of these three things, your help is greatly appreciated.
08-31-2007 07:54 AM
08-31-2007 09:24 AM - edited 08-31-2007 09:24 AM
Message Edited by andre.buurman@carya on 08-31-2007 09:24 AM
08-31-2007 09:34 AM
07-27-2011 02:27 AM
Hello, I downloaded your NE-50x.vi , Ballon diameter.vi for the use of syringe pump project, which is quite useful but i would like to have enquiry that can I still use NE-50x in Ballon Diameter.vi or have to create another vi for using NE-1000 syringe pump
Thanks for ur help
Best Regards
SK
07-29-2011 05:39 AM
hello,
i am referring your RATEST.VI 220kb from this link: http://forums.ni.com/t5/LabVIEW/How-do-I-create-an-excel-file-that-has-the-volume-output-and-the/m-p...
which was quite useful for my project part that i am doing. If you don't mind, can u please help me explain in details how u decided to design such kind of very nice block diagrams in labVIEW.
I just used one syringe pump NE-1000, and i need to control the three parameters: diameter, volume, and flow rate.
I just want to enquiry about the big while loop work till to the end. Can u please explain ur useful vi?
Thanks heaps
Looking forward your kindly reply.
SK
08-01-2011 05:16 PM
The NE-50x.vi is only designed to work with the NE-500 and NE-501. It could possibly work with the NE-1000, but that would depend on how the manufacturer designed it. If you have the manufacturers documentation, you may be able to determine if the two models use the same communication. If they communicate differently, NE-50x.vi will not work.
In regards to the ratetest.vi, it was written by someone in the community several years ago. If the manufacturer can provide you with vi's updated for the NE-1000, you may be able to simply replace the NE-500 vi's in ratetest.vi, otherwise you would have to rewrite each of the vi's yourself.
I hope this answers your question.
Luke B.
