What you might consider doing is using a sequence. Run the data through this sequence and inside of the sequence, put a delay equal to the time you wish to delay the signal. Then, the output will not be available until the delay has completed.
If you need continuous streaming data, this might not work too well. Then, you will need some sort of a data buffer - perhaps using a queue might be one possible solution. I have not used it, but I think that queues can have a time stamp. You could possibly artifically alter the time stamp.
Hope this helps,
Jason
