How do I create a VI which sweeps from 1000 to 11000 then back to 1000 again
Hi
I feel like a newb asking this question considering that the last thing I did was a GPIB interfacing program, but I'm trying to create a VI which simple sweeps a number starting at 1000, up to 11000 then goes back down to 1000 again, the steps are taken in increments of 1000, attached is a program which almost accomplishes this goal, except that when I give out a positive number it just goes 11000,10000,11000,10000 so on and so forth, any help would be appreciated.
(2,293 Views)
Instead of analyzing your code to understand exactly what causes this to happen (I don't like nested conditions which look like that), I will just suggest that you take a more simple approach. Attached is one example - if it needs to go up, it goes up, and if it needs to go down, it goes down. This could probably be made more efficient and simple, but this is just a quick example.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here and here are a couple you can start with. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
___________________
Try to take over the world!
(2,276 Views)
Not sure if I understood you correctly but I think something like this might be what you want.
(2,275 Views)
See attached VI. I guess Sweep 4 is what you need.
(2,274 Views)
