How do I convert a comma delimited txt file to a 1d array?
 I have a newbie question. I have a txt file with a series of numbers delimited by commas I have been trying to convert them to a 1d array of numbers precision is 6.
(2,576 Views)
Have a look at the "Read from Spreadsheet File" VI
(2,573 Views)
You really have two options here:
1) Just use the Read Spreadsheet File.vi, be sure to set the delimiter to be a comma.
2) Do what the above mentioned VI does (just will less overhead and the ability to pass on errors) and just read the entire text file and then use Spreadsheet String To Array.  For the SSTA, you need to set the delimiter to a comma, set the format to %f, and wire in a 1D Array of double to the type.
GCentral
(2,529 Views)
