How do I click on a cell in a table control, and display the value in a string?
What I would like to do is to click on a cell in a table control, and have the value of the cell be displayed in a string indicator. What ever cell I click on, I would like the value to be displayed in the indicator.
Thank you!
(3,054 Views)
Accepted by topic author SciManStev
Use the property "Edit Position".
(3,048 Views)
... or
Event >>> ouse down for table.
Use Coords" to feed invoke node "point To Row Column" and returned "Cell Postion" can be unbundled to produce the row and column tht can be used to index out the value.
Ben
(3,044 Views)
Thank you! I had tried everything but that. I knew it had to be easy.
(3,043 Views)
Also thanks, sorted my Table issues too. cheers
(2,997 Views)
