How do I cancel a sub vi stuck in an infinite loop?
I am attempting an implementation of the Constrained Nonlinear Optimization sub vi.  It works perfectly 99.9% of the time but gets stuck the other .1% of the time.  It is supposed to time out when it cannot find a solution, but it is failing to do so.  Consequently my VI regularly crashes.
Apparently this is a known issue with this subvi.  The NI whitepaper mentions that this is caused by a subvi while loop that can get stuck in an infinite loop.  The work around is suggested to be to add a counter to the loop and exit it after a certain number of iterations.
I can find the infinite loop occuring in the subvi.  But the sub vi opens as a clone and will not let me edit it.  How do I work around that?
Failing that, is there a way from the main vi to cancel the optimization vi after a certain time so that the program can move on?
Suggestions would be appreciated.
(2,445 Views)
Abort the program. Press ctrl+M when you have VI opened as clone. This will open it in edit mode.
(2,441 Views)
Thanks for the suggestion.  That did the trick and saved me a lot of time not knowing what I was looking for.
(2,377 Views)
