I want to programatically cancel on ongoing TCP Open Connection prior to its timeout expiring. How do I do it? I'm using LV 2012.
I took a look at this thread: How to kill TCP-IP Listen or Open Connection while they are waiting to connect? but it didn't help.
I'm thinking I could put the TCP Open Connection in a VI, then invoke the VI by opening a VI reference to it and starting an asynchronous call that gives me a reference to the running VI. I could then use an Invoke Node on that reference to call Abort VI when I want to terminate it.
I tried this in the LabVIEW environment (i.e. I didn't compile) with a dummy infinite loop VI that blinked a boolean indicator. It worked (the subVI stopped and the invoking VI continued), and did not cause an error 1000 despite the help's admonitions to only use Abort VI on a top-level VI.
So far so good, but am I asking for trouble? And is there a more elegant way to do this in general, i.e. abort a SubVI that for reasons beyond my control doesn't have a canned abort function?
Thank you.
