10-13-2010 04:46 PM
Gumby question here... I am just starting to work with tabs.
I have one tab of several that is the "Start Up" tab. Every time the user clicks the little white "Start Arrow" I want the program to automatically show the "Start Up" tab. The user then selects various communications ports, etc. When finished setting things up, the user clicks a "Start Test" button. At this point, I want to show the "Main Screen" tab instead of the "Start Up" tab. How do I do this?
See attached vi with dummy tabs that show the buttons I want on the tabs I want.
Thanks!
Solved! Go to Solution.
10-13-2010 05:01 PM
Create a property node for the tab control. Set the property "Value" to the desired tab. After creating the property node create a constant for the value property. This will be an Enum of your tabs.
Note: When you add or delete tabs from the control you will need to go through and recreate the constant. It is not updated automatically.
10-13-2010 05:09 PM
Worked like a charm! Thanks!
