I have written a dll in C++. Here is the exported function: extern "C" __declspec(dllexport)void Get_GPS_Error(int Cmd,TIniTable& Output); How do I access the reference to the initable Output in LabVIEW 8?
A reference is the same as a pointer - it's just a C++ compiler trick to make it look like something else - so you create your binding in LV the same as if it were defined
