02-04-2014 11:50 AM
I am a Biomedical Engineering student trying to create a Data Dashboard which can be used to monitor an ECG waveform.
I am able to save the data points of the wavefrom into an Excel spreadsheet and I want to be able to send these points to Data Dashboard to recreate the signal and view it on a graph on my Ipad (using data dashboard app).
Could someone please give me some instruction as to how I can use LabView to get this Excel data INTO Data Dashboard?
Thanks in advance,
Alex
02-05-2014 01:55 PM
This Whitepaper may be of some use to you. You could take the data from excel into LabVIEW and then have the data output into shared variables for data dashboard.
http://www.ni.com/white-paper/13757/en/
02-05-2014 02:06 PM
02-11-2014 10:12 AM
Hi Rob,
Your reply did help! I am able to send a shared variable to data dashboard succesfully and view it on an indicator on the Ipad. However, I want to be able to send data of a graph with pre-existing X and Y values from a file path (excel spreadsheet) saved on the PC.And finally display these same points on a graph on data dashboard. Do I need to make a web service for this type of application? If so how do I accomplish this with the web service?
Alex G.
02-12-2014 09:55 AM
I've only used data dashboard to take data that my PC is receiving/logging and update it to my iPhone through the app and shared variables. Not sure how you would do this if you already have the data in Excel other than to pull it out of the excel file and then write the data to the shared variables to see in data dashboard. You might try checking out the other dedicated forums to see if someone else has done something similar you your project.
