02-12-2014 06:12 AM
I am using Labview 2006.I am using a switch(OK button),if it was pressed I want to open ma 2nd Vi file,it was done,but the problem was there is also a switch in the 2nd Vi file if it is pressed I want to open my previous Vi file,but it is not happenings it gone stuck. Can any one help me???
Thanx ..
02-12-2014 07:24 AM
There might be one of several reasons for this behavior. Please attach your VIs (NOT pictures of VIs) to a post, so the people here can see what you have done and suggest a remedy.
Cameron
02-12-2014 07:27 AM
Thanx ..
There was not LabVIEW 2006. Do you mean LabVIEW 6? Or maybe LabVIEW 8.2 (which was released in 2006)?
I'm not really understanding your problem. Do you just want to close the second VI and therefore give focus to the first? Showing some code helps explain things too.
03-01-2014 07:27 AM - edited 03-01-2014 07:29 AM
Hello
I'm using LabVIEW 2013!
I've almost the same problem. I have a Main VI that I open. Then I want to press a button and open a VI 2 (The Main VI should hide). When I close the VI 2, the Main VI should appear again. So there is always only one window visible.
I've tried it but the problem is, that when I go back to the main VI, it's like frozen. It looks like its deactivated.
Here are pictures of both the Main VI and the VI 2 (the code files are attached also)
Does anyone have an idea what the problem is??
THANKS
03-18-2014 04:09 PM
@wasauchimmer wrote:
Hello
There are several things wrong with your VIs the most important is that you aren't using data flow. I'd recommend some free LabVIEW training:
3 Hour Introduction http://www.ni.com/white-paper/5243/en/
6 Hour Introduction http://www.ni.com/white-paper/5241/en/
LabVEW Basics http://www.ni.com/gettingstarted/labviewbasics/
Self Paced training for students http://www.ni.com/academic/students/learn/
Self Paced training beginner to advanced, SSP Required http://sine.ni.com/myni/self-paced-training/app/main.xhtml
LabVIEW Wiki on Training http://labviewwiki.org/LabVIEW_tutorial#External_Links
Attached is a zip with VIs that I think does what you want. Run the main and then click the button to show the second window. Then close it (or hit stop) to close it and show the main again. From there you can close the main to stop, or click open again to re-open it.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
03-20-2014 06:37 AM
Thanks for the example. That's exactly what I was looking for!
Thanks also for the links! Will check them 🙂
03-20-2014 09:30 AM
Giving Kudos is a great way to say thank you.
