08-02-2009 04:58 AM
I want to use use Itemsyms in my first column of mulitlist box. But it always exist with first content of ItemNames. I want to
know whether I can put a Itemsyms in a single column and data in other columns. Should i create a null string array and set it as
a first column? And the Itemsyms only can be put in the first column?
I feel confused now after try many times. 😞
please give me help.
attached my vi.
By the way, When i try to set number of row and column of list box, for column, the set value is 5, but the value get from property is 4.
I don't know the reason.
thanks
br.
08-02-2009 05:29 AM
Blog for (mostly LabVIEW) programmers: Tips And Tricks
08-02-2009 11:45 PM
Thanks.
How about other my questions? Please give me your advice.
Thanks.
08-03-2009 02:21 AM
mmm2006 wrote:Hi,
Thanks.
Thanks.
mmm2006 wrote:I want to use use Itemsyms in my first column of mulitlist box. But it always exist with first content of ItemNames. I want to
I do not understand this term "Itemsyms".
If you create a "null string array", your first column will become empty. You want this way or you want to replace your data in the first column? Both are different...
You can very weel put your "Itemsyms" in a single column & data in others.
08-03-2009 09:24 AM
Hi, Partha,
I only want to add a symble into first column and data in other column.
Please tell me how to do it.
Thanks.
br.
08-03-2009 08:13 PM
Hi, all.
keep asking. Appreciate any help about this problem.
Thanks.
08-03-2009 09:03 PM
It seems that the itemsyms only applys to the first item column of the MClistbox (it seems that you want to add the symbols on the row heads of the box, but it seems not possible currently). So you can create the string array (which is used as the item name) with the first column empty. So the first column of the box is filled with the symbols and the item name begin from the 2nd column. Please refer to the VI I attached.
08-04-2009 12:07 AM
hi,rui_huang
Thank you very much.
I will try.
Br.
08-04-2009 09:39 AM
HI,
When operation, there is a rectangle in cell,just like my attached picture.
Is there no other solution?
Thanks.
08-04-2009 08:21 PM
I tried for some time. It seems that the rectangle cannot be removed and is used to indicate that the cell is being selected.
