How can i train OCR characters through labview
As I told earlier, you need to create OCR file first to train your characters. Use " Vision Assistant" to create this file.
I created OCR file (*.abc) for given images. it reads only those characters (A,B,C,D,E,S,T,U,Z). For remaining characters, you have to create.
I recommend you to read VISION software user manual (before processing images)
http://www.ni.com/pdf/manuals/371007a.pdf
Munna
Message 21 of 25
(1,316 Views)
Dear Munna
Thank you very much for your time and your reply.
I hope that I understand you correctly.
I think because My English language is poor, I couldn't explain my problem correctly.
I know that I need to create OCR file(*.abc). I try to create an OCR file(*.abc) with attached training code. But as I've said before, I have the following problem in creating the file(*.abc):
{{{{ When the image is called, and the system detects an area around each character that is marked in red (picture 1), I would choose an area around a character  that is marked in green, then i put the  actual amount of character in (CORRECT TEXT) and push ok button (picture 3,4).
In this way, I see my teached character in (OCR RESULTS) and (TEACHED CHARACTERS)(picture 4). But after the way, the code cannot recognize red zone around the characters.( picture 5)}}}}
In fact, when I create my OCR file(*.abc) with this method, OCR cannot detect characters.
sincerely
Tandis
Message 22 of 25
(1,296 Views)
Thank you very much
My problem is solved
Sincerely
Tandis
Message 23 of 25
(1,279 Views)
Glad to know your problem is solved.
Sorry I was not able to explain you my code as I don't have NI Vision module in my current development. OCR Teaching code was developed in 2008 and I don't remember.
PBP
Labview 6.1 - 2019
Message 24 of 25
(1,263 Views)
Dear PBP
Thank you very much for everything. Your code is fantastic.
Best regards
Tandis
Message 25 of 25
(1,247 Views)
