How can I view the program threads, similar to VI Hierarchy?
Is there a tool/viewer/whatever that I can use to see which VIs are used in which execution threads?
I am working on an old, large program and can't really check them all in file properties.
(2,510 Views)
The attached LV 6.1 code should list all of the VI's in memory and sort by prefered execution system.
It uses a LV reference to get a list of all of the VI's in memory.
The returned array is used to open a reference to all of the VI and then a property node is used to get the "Prefered Execution System" and Priority. These are then bundled along with the VI name and the resulting cluster is accumulated on the edge of a For loop. The array is then sorted and displayed.
I hope this helps,
Ben
(2,510 Views)
