How can I stop playing sound files if a falling edge is detected?
Hi all,
I want to realize an easy function in labview, read the data from DAQ, if an rising edge is detected, play .wav files, if a falling edge is detected, stop playing files.
I know how to play sound files, I realized it using case structure as shown in the picture, but I don't know how to interrupt it if falling edges are detected...
Could anyone give me some suggestions? My code is attached.
Thank you very much!
(2,953 Views)
Use Sound output start/Sound Output Stop for Rising and Falling Edge (Configure outside the loop once before the Loop Executes)
(2,909 Views)
Palanivel,
Do you have an example showing that?  I haven't seen any sound VI's called "Sound Output Stop for Rising and Falling Edge".
(2,890 Views)
If this is intended to run in a lab environment, you're probably okay; if this is going to be in a cubicle, your co-workers will probably want to strangle you.  I'm just sayin'.  😉
Bill
CLD
(Mid-Level minion.)
(2,870 Views)
