How can I set a front panel window's "Origin" property, as of LabVIEW 8.2?
This "Front Panel Window" property appears to have gone away since LabVIEW 7.x. Is there some new way to set a panel's origin?
(3,808 Views)
It's not gone away, it's moved a bit.
The splitter bars allow you to have multiple panels on a single VI, so they had to change things a bit.
First you need to get a reference to the "VI Panel", then "Pnl Panes []" (note this outputs an array of refs), then index out your panel and finally you'll get to the Origin property. Since you only have a single front panel, you can just use the Index Array function and grab the first element from the Panes property.
Ed
Message Edited by Ed Dickens on 01-18-2007 12:20 PM
Ed Dickens - Certified LabVIEW Architect - DISTek Integration, Inc. - NI Certified Alliance Partner
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,805 Views)
Got it, thanks.
(3,799 Views)
