07-10-2006 06:11 AM - edited 07-10-2006 06:11 AM
Message Edited by sasa14@inet.ua on 07-10-2006 06:12 AM
07-10-2006 07:05 AM - edited 07-10-2006 07:05 AM
It really depends. Your PC can only have one IP adress per interface. Such interfaces can be virtual, meaning only a software interface but they nevertheless need to be defined as an interface. If you have a newer version of LabVIEW (>= 7.0 or 7.1) you can use the "String To IP" with an empty input, right click on the icon and select "Multiple Output". This will return you an array of IP addresses, one for each interface available in your PC. Wire them to a loop in which you have set the "String To IP" node with the "dot notation" input set to true and you get at the other side of the loop an array of strings with your IP adresses.
@sasa14@inet.ua wrote:
Hello all.
I have in the host computers two IP address: Ethernet and Internet.
How can I see both IP address ?
Now I can see only one IP address : Ethernet.
With respect
Aleksandr.
Message Edited by rolfk on 07-10-2006 02:06 PM
07-10-2006 09:14 AM
Your post makes little sense. There is no distinction between ethernet/internet IP addresses, they are all plain IP addresses. (Sometimes, the MAC address is called ethernet address, but this is something entirely different).
07-10-2006 09:20 AM
07-12-2006 01:52 AM
