06-23-2014 07:01 AM - edited 06-23-2014 07:02 AM
@Eram wrote:
So where is destination folder defined to save jpeg files?
You can specify a path using one of the inputs:
path to JPEG file specifies the path to and name of the JPEG file to write. If you do not specify a path, LabVIEW displays a file dialog box so the user can navigate to the file. |
You can read more about the function here: http://zone.ni.com/reference/en-XX/help/371361H-01/lvpict/write_jpeg_file/
06-23-2014 07:11 AM
Just an addon. Use an PNG for a better image format. Use a the function and connect the filepath
06-23-2014 07:19 AM
It is wherever you last went to with a file dialog. I would recommend supplying a file path to the write VI.
06-30-2014 08:32 AM
I have a problem with it.
1- I want to save data from a graph in vector. how can i save this?i mean,i want to save image data during changing input. i think i need run save botton and end save botton.
thnx
06-30-2014 09:23 AM
In your save button, Try Mechanical action "switch until released"
06-30-2014 09:58 AM
thnx, how can i save my data(not graph) ?(e.g in excel file?)
thnx
06-30-2014 01:19 PM
Have you searched the forum? you will find loads of examples. Post back if you are still finding it difficult
